Types of Sandblasting (home garage) - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: Which method of Sand Blasting Do You Prefer?
Pressurized Pot 3 50.00%
Gravity Feed gun 2 33.33%
Siphon Gun 2 33.33%
Other 0 0%
Multiple Choice Poll. Voters: 6. You may not vote on this poll
Old 02-24-2010, 08:56 PM
This thread is about the small sandblaster in a home garage (me), etc., not a shop (but please contribute if you would be so kind).
I have a Harbor Freight 40# Pressurized blaster unit (that I'm having trouble with - different thread).
I decided to try two other methods since I was having probs with the pot.
First, I bought a Harbor Freight gravity feed gun which was about $20, then I bought a Northern Tool siphon gun, which was also about $20.
I found that when I was able to get the pot working, that it removed the paint fast when compared to the other two methods. But again, flow problems made it frustrating.
The gravity feed worked well, but you have to fill the tank(?) on top of the gun fairly frequently. I believe it will work well for small parts. I pull the trigger to get the air going, then open the media valve and turn off the valve whenever I stop blasting.
I really like the siphon gun (even though it removes material relatively slowly also) because I can stick the pick up tube into a 5 gallon bucket 1/2 filled with media.
The only problem here is that when the media is being sucked out of the bucket, it can suck it up and run dry with media all around it except at the pick up tube. Gently kicking the bucket helps, but is a temporary fix.
I keep the bucket slightly tilted, which helps the kicking procedure. Again, GENTLY kicking the bucket keeps the flow from dying (pun intended-ha ha).
The blasting gloves that I put in my home built cabinet were from Harbor Freight's blasting cabinet (I ordered them separately) and they are too tight to take them on and off all the time to adjust the media in the bucket by hand (hence the kicking). Rocking the bucket with the bottom of your foot to distribute the media is shaky at best (could get a second job in the circus I guess).
I'm usually wearing my respirator because my blasting cabinet is not air tight even though I have my dust collector running. I also wear it when I'm pouring the media into the bucket or the tank of the gravity feed gun and the pressurized pot. Pretty much all the time. It's a pain in the butt, but I feel a lot better knowing I'm not breathing that stuff in.
Jump right in, and thanks for your input.
Chaz
Old 02-25-2010, 07:46 AM
I have an old siphon gun that works like a charm. As sell as a "Speed blaster" which is what I usually use because I am not doing a lot of blasting. I did get a pressure blaster from the Chinese Red Army store (HF) years ago and it worked like CRAP and brought it back.
Old 02-25-2010, 08:15 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
only thing in hf worth carrying out the front door is the cash register.
Safest garage heating method rayn Garage - Tools 6 08-30-2009 12:33 PM
Heating the garage cheap and safe lugog Garage - Tools 4 10-03-2008 05:42 PM
garage wiring montea Garage - Tools 33 01-18-2007 08:33 AM
Car thieves using VIN #s willys36@aol.com Hotrodders' Lounge 18 05-18-2003 11:44 AM
A new home 4 me he, a new home for me he! HemmiGremmie Hotrodders' Lounge 8 05-09-2003 04:07 PM
