Typical AC system capacity? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-01-2008, 11:11 AM
powerrodsmike's Avatar
Wiki Edits: 161
Originally Posted by carsavvycook
The spraying of water on a fully charged, good working system, will drop the pressures about 10 degrees on the low side, and 15-20 on the high side. This is a good indicator to what your pressures will be at highway speeds during normal driving.
You mean pounds?
I'll buy all that. Now that there are actual values for Weirdbeard to go by.
Later, mikey
BE different....ACT normal.
  #17 (permalink)
Old 06-01-2008, 11:20 AM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Yes I did mean pounds, sorry for any confusion. More importantly though he now will be able to fix it right, and by spraying the water get enough freon in the system without increasing the high side to dangerous levels.
System One Polishing/Buffing System texczech Body - Exterior 1 12-26-2006 04:27 PM
Exhaust System Sizing leejoy Engine 9 10-04-2006 07:38 PM
AC conversion bassdude404 Engine 10 09-28-2006 02:19 AM
73 nova/425hp with AC Sagacious Engine 2 09-25-2006 04:37 PM
