Typical Machine Shop Costs - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2005, 06:21 PM
I intend to build a 500 hp. street / tow car 455 Pontiac engine. I will be doing all work other than Machine work. Been a while since I built my 1961 Chevy, 348 Tri-power so would like some current info on machine work. Need prices on Hot - Tanking, line bore and hone cylinders (ie. fit pistons, turning the crank and line bore the crank journals. Going with new Alum. heads so don't need walve work. (by the way, anyone interested in 1971 Pont. 455 heads with S.Stl valves and hardened valve seats?) I know prices vary by location, I'm in Colorado Springs, Colorado. Not building a race car but want a machinist that has!
Old 10-08-2005, 08:44 PM
coldknock's Avatar
The best advice I can give is to call the shops in your area.
Anywho, my shop charges $350 for cleaning, bore and hone with torque plates, installing new cam bearings, freeze plugs and oil plugs and squaring the decks. $200 for crankshaft balancing including matching the rods and pistons, a little extra if they have to add weight to the counterweights.
It might be more or less in your area but look for the shop with the best reputation, not the best prices.
Larry
Old 10-09-2005, 06:51 AM
docvette's Avatar
Wiki Edits: 12
Price
Doc here,
Here in California, Labor rates are right at 99 to 120 bucks an hour...where non book jobs applies..
As was said price is not the deciding factor, integrity and honesty is..coupled along with reasonable down time..and success rate.
Call, or better yet GO around to various shops, and talk to them, maybe if they'll let you look at the shop..develop a rapport with the guy for best results. You wouldn't do any less with your Doctor, Right?
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 10-09-2005, 07:10 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Larry
My area is about the same...it does come down to who you feel good about doing your work and finding someone you can work with well..
OMT
Machine Shops in AR or MO Wmarden Engine 7 03-15-2012 10:19 AM
New member / New shop Electrical ideas? Russ - Blown 85 SS Garage - Tools 22 12-07-2004 01:07 PM
Looking for a good machine shop. Dr.Feelgood Hotrodders' Lounge 1 11-13-2004 11:42 PM
San Francisco Area Paint Shop billcar670 Body - Exterior 3 10-24-2002 06:33 PM
Engines from Ken's speed and machine shop bobcat17 Engine 3 07-07-2002 10:29 AM
