Tyvec inside garage - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2010, 08:16 AM
Tyvec inside garage
I have a detached two car garage that I insulated last year with 2.5" closed cell foam board that has a black fiberglass lining on each side. The insulation was installed between the studs and rafters. I would like to wrap the inside of the garage with Tyvec so help seal the dust in from the insulation and make the walls white to help reflect light. I also like the added benefits for helping to keep the garage warm in the winter. What I don't know is which side of the tyvec should face the inside of the garage? I am thinking I want the writing exposed inside the garage so any moisture in the garage from heating it with a torpedo heater will not get into the insulation. It would also allow any moisture in the insulation area to come out. Is this correct?
Old 11-05-2010, 10:11 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
From the Tyvek site:
15. Can DuPont™ Tyvek® be used with the lettering facing in?
DuPont™ Tyvek® HomeWrap®, DuPont™ Tyvek® StuccoWrap®, DuPont™ Tyvek® DrainWrap™, DuPont™ Tyvek® CommercialWrap®, and DuPont™ Tyvek® CommercialWrap® D are equally effective in both directions. However, DuPont™ Tyvek® StuccoWrap®, DuPont™ Tyvek® DrainWrap®, and DuPont™ Tyvek® CommercialWrap® D have a specially engineered surface that should be placed with the grooves in a vertical direction.
http://www2.dupont.com/Tyvek_Const_G..._US/index.html
Keep in mind it is flammable.
Old 11-05-2010, 11:24 AM
thanks for the info
Old 11-05-2010, 03:46 PM
TYvec in garage
IMO you might want to consider drywalling the garage rather than using the Tyvec.
The drywall is fire proof and will also cut down on moisture, noise and heat transmission as well as keep the temperature moderate.
If it is an open garage, rather than doing it yourself, consider hiring pros to do the job. They would probably knock out the job in one day including the ceiling and when you consider the value of you time and effort the Pros might be cheaper. Ask them to do a garage quality mud and Spackle job. Then you could prime and then paint the walls and ceiling gloss white yourself. The prime and painting could be done with a spray gun or a super large roller. Remember it is not like you are doing you living room. The gloss white will reflect light and make the whole place much more enjoyable. The gloss white will clean up easily too. I'm a homeowner handyman and have done this sort of thing and I will never, ever try to hang drywall again. I'll hire the pros.
Walt in CT
Old 11-05-2010, 04:58 PM
I would love to drywall it but don't have any money. I also want to keep the ceiling rafters exposed which would be very time consuming with drywall. I appreciate the input though. Some day I will drywall it. Is tyvec more flammable than the wood studs and rafters in the garage already?
Old 11-05-2010, 05:37 PM
Put it this way.....are wood shavings more flamable than a chunk of 2x4? I didn't know Tyvek would burn, but it's very thin, so as it does, it wouldn't take much for it to catch.
I had a fire in my garage. Only thing that saved it was I installed a full inch of fire-proof gyp-rock (drywall) on the ceiling. Covered it with 4x8 sheets of 3/8 and then went over it again with 12x4 sheets of 5/8.
If you don't have the cash now, I think I'd leave it open studs....probably less likely to catch and I would think, easier to put out of it did.
Buy a fire-extinguisher....or two. And make sure you know how to use them. That won't cost a lot.
By the way, never, ever, never change a gas tank in your garage with a kerosene heater going.
Old 11-08-2010, 08:12 AM
I am guessing that is how your fire started?
I have a fire extinguisher in the garage and it is not one of those little toy ones most people have.
I will not do the tyvec and start saving up to do drywall. Thanks for the input everyone!
Old 11-08-2010, 08:32 AM
Good Guess. Changing the gas tank in an old RX7. Tank did not have a drain plug, so there was a bit of gas still in it. Got the tank out. Started pouring the gas out into a proper gas container using a funnel. Funnel had a very fine filter screen and the odd time the funnel would over-fill and a bit got on the floor.
Spread over the floor until it got to the kerosene heater. I saw a flicker of light and looked over to see a wall of fire coming towards me. I only made it 1/2 way to the door before I couldn't see due to black smoke, but I got out and called the Fire Dept. My big fear was that this was April 1st and I thought they might think it a hoax, but they showed up.
Fire also caught the battery of my 66 Mustang on fire. I didn't know a lead-acid battery could burn like that. Most underhood damage to the Mustang was from the foam the fire dept used. Very caustic and rusted everything.
Plastic smoke alarm on wall dripped down the wall like candle wax. Plastic coated handles on various tools melted, and some of those tools were on the floor, the coolest spot.
Fireproof gyp-rock was all that saved my garage. There was living space above the garage (summer guest house), and I was told the building code called for a full inch of the fireproof stuff because of that. Following the code turned out to be a very good idea.
In hindsight, the whole thing was my stupidity....a stupid accident, but I have yet to hear of a "smart" accident. I still feel stupid though. There easily could have been an explosion vs just catching fire.
Old 11-08-2010, 02:02 PM
wow, thank you for sharing that story. I am glad you made it out ok. I will think twice before pouring anything highly flammable when I have a heater on the floor running now. I think I will be upping my priorities to get drywall in the garage.
I was wondering why you wanted an inch of drywall, makes sense now. I think I will just do 5/8" since it is a detached garage. Did you use the green stuff, mold and mildew resistant?
Old 11-08-2010, 02:17 PM
It wasn`t green, but not sure green was available then, or maybe it depends on the brand. But it was marked Fire-Proof or Fire-Resistant. Mildew resistant would be a good idea though in a non-heated garage.
Old 11-08-2010, 07:47 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Just a hint. If your garage has 9' walls and you plan on finishing it at some point, buy "stretch rock". It is 4-1/2' wide. Hang it horizontal and the tape seam will be waist high. This saves from having to piece a 12" strip in and having another seam to finish.
Old 11-08-2010, 10:21 PM
Grand PooBah
use the cheap thin metal siding...
metal siding on the ceiling and walls is the only way to go..
Old 11-10-2010, 01:22 PM
Grand PooBah
when i did my garage, i insulated, then put up that clear plastic as a barrier then drywalled.. did the ceiling the same way..
if i had to do over again i would have used the thinnest metal siding i could find for the ceiling and walls
Old 11-11-2010, 08:17 AM
what metal siding are you guys talking about? Can someone post a link with a picture?
Thanks
Old 11-11-2010, 08:47 AM
delawarebill's Avatar
metal ceiling
u can look into lowes, home depot stores. they carry mtl roofing..
Painting car in garage in Texas and general paint questions. V8 Super Beetle Body - Exterior 24 06-04-2013 07:47 AM
Garage paint booth. A few questions concerning the design and safety V8 Super Beetle Body - Exterior 25 08-17-2010 12:06 PM
garage wiring montea Garage - Tools 33 01-18-2007 09:33 AM
rust inside cab, how much to paint ljjjrome Body - Exterior 5 06-23-2006 09:38 PM
painting in garage... water heater concerns? Eddie N Garage - Tools 18 03-09-2003 09:06 AM
