Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - U Coat it floor coating
Old 12-10-2008, 11:15 AM
roger1's Avatar
roger1 roger1 is offline
Vince,
I think you will be happy with Epoxy-Coat for an easy to apply single coat system that will hold up well to heavy use and abuse.
How are you going to prep your floor? I would advise grinding (like I did) versus acid. Also, the acid they gave me with the Epoxy-Coat kit wouldn't do squat as far as etching my floor.
My advice would be to throw away the flakes and the acid that comes with the kit. I wouldn't use the non-slip grit either. The squeegee they give you works well but I would buy an 18" roller frame and a few 3/8 nap 18" roller covers from Lowes.
I would also advise you to have a weed blower handy to pop the bubbles you will get during the application.
