U Joint bearing question...please help - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2003, 07:17 AM
redcamaro4spd's Avatar
drive it like you hate it
hey guys, in the midst of pulling my tranny and when the drive shaft came out, one of the bearings in one of the u-joint caps fell out. Does anyone know if you can buy these off the shelf? Or do I have to get a brand new u joint?
Thanks
Old 10-25-2003, 07:27 AM
adtkart@aol.com
Usually you have to buy the whole u-joint. The bearings are all different sizes. Unless you have a collection of old caps and bearings, you are out of luck. They are usually only about $20.
Old 10-25-2003, 11:50 AM
former member of HR.com
If you are re-working or replacing your transmission, PULLEASE put in two brand spanking new U-joints when you put it back together. Driveshafts have been known to fall off when the transmission repair has overlooked replacing U-joints. You can find lifetime U-joints at Advance Auto for about $15.00. Also replace the rear U-joint "U-bolts" that clamp to the rear yoke. You can get those for about $6.00 also at Advance Auto. Summit sells a nice set of "Billet" rear U-bolts for $20, and they have a bigger and better grip on the U-joint. If you're going to be hot rodding around, use those instead.
Old 10-25-2003, 12:00 PM
dmorris1200's Avatar
doesn't play well with others
Ditto! Don't take a chance on such an inexpensive part.
BUILT FORD TOUGH
Old 10-25-2003, 05:33 PM
alrite, thanks for the advice guys, I did not realize ujoints were that cheap. These ujoints were just replaced as the old rear u joint broke and I spit out a driveshaft, so if I have sometime I may pickup a new set and put them in. Thanks again...
