U-Joint modification - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2011, 11:30 AM
UngerMarkus's Avatar
Tuck´n´Roller
Hi guys!
I just installed a Th400 in favour of my blown th350. Unfortunately the th400 yoke doesn´t fit the U-Joint. The driveshaft requires a cap diameter of 1.125'' and the new yoke a cap with 1.063''. The caps look pretty beefy. Do you think it is a wise idea to put 2 of the caps in a lathe and turn them down to make them fit?
Should be a temporary solution, until I receive a conversion u-joint.
thanks
Markus
Old 03-14-2011, 12:05 PM
prostreet6t9's Avatar
Differential/Driveline
Your 1.125 cap joint should be a inside snap ring style joint. Google 5-3022X spicer. That should be the conversion joint you need.
steering bell joint = U joint ? user151 Suspension - Brakes - Steering 5 04-23-2011 11:53 AM
289 modification 84fordcourier Engine 5 05-12-2009 12:55 PM
Cab-over modification Cabover Body - Exterior 3 09-28-2007 03:05 PM
55 frame modification (help) Bobberaz Suspension - Brakes - Steering 1 03-30-2006 10:43 PM
