U-joint question....... - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2006, 08:35 AM
I am replacing the u-joint in a drive shaft from a 68 firebird with an auto and the original u-joint has a hidden groove on each cap with plastic(?) injected in it to hold the u-joint in place.
Anyway, my question is....will a replacement u-joint use clips on the inside of the yolk flanges to hold the joint in place instead of the injected plastic?
Any thoughts or comments will be greatly appreciated!!
Old 11-17-2006, 09:07 AM
yes,also remember to heat the caps where the plastic is or you will never get them out.
Old 11-17-2006, 09:17 AM
u-joint question......
Yes it will have new clips to hold it in place.
We sometimes use a torch to heat plastic up,of course be careful if you do this.
In fact,melting the plastic is about the only way this u-joint will come out many times. Good luck!
Old 11-17-2006, 09:21 AM
sorry double post
Old 11-17-2006, 09:22 AM
Thanks very much Barny and Briscoe for your response! I hear ya about heating the caps up. I tried for a long time with no luck until I did heat them up and then the plastic came oozing out of the little hole sorta like the little firework "snakes" we used to buy for a nickle when we were kids,hehehe.
Old 11-17-2006, 10:27 AM
u-joint question
Jimmy watching that plastic ooze out can be very therapeutic!
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
383 stroker 73monte Engine 10 12-05-2009 08:02 PM
Front Ball joint ... PICTURE bg Suspension - Brakes - Steering 17 04-16-2005 01:24 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
