u joint removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2005, 04:41 PM
u joint removal
Hi, I've removed one side of the front axle on my 94 ranger 4x4 cause the u-joints are bad...I'm trying to take out the joints, but having problems. Turns out that there are no clips holding it in, or none that I can really see. It's kind of weird, but the face of the bearing cap looks just like the replacement, but the replacement comes with clips... any ideas?
also, how do you work on the yolk attached to the transfer case? I can't seem to remove it. Thanks, Adam
Old 12-10-2005, 05:13 PM
Are there little globs of what might look like plastic on the ears where the bearing cups are?
I know that GM uses a melted nylon to hold them in..
I had that problem once and a GM tech told me to heat it with a propane torch and the plastic stuff comes squirting out like a big zit! It works!
The preferred method is to use a arbor press.
Don't get it too hot.....
The new ones require clips usually on the inside of the cross..
Old 12-10-2005, 05:22 PM
its a 94 ford, so it may be inside the cross, the replacements have the outside clips tho
Old 12-10-2005, 05:31 PM
Maybe they gave you the wrong parts?
Just a thought... Do you have the little globs? They are usually the size of the buttons on your watch, maybe a little larger.
Old 12-10-2005, 06:18 PM
So yup, in the cross, little clips that don't bend...I'm still having a ****** of a time getting em out. Bought a press for this, to small with the sockets...any good ideas? Thanks, Adam
Old 12-10-2005, 07:03 PM
You can't get the clips off? Or the bearing caps?
I have almost always been able to get the clips off with a small chisel or screw driver and a hammer.. Soak them with a good penetrating oil..
Once I had to cut the cross out with a torch and just left the clips, they push to the inside anyway..
If the caps are stubborn, there are mixed opinions on this..The main thing is common sense.
Put the yoke in your press and warm the ears while under pressure from the press. DON'T get it red hot! That will make it brittle.
When I have done it like this in the past, I hear a pop or ting and they easily press out the rest of the way.
Some guys say never heat the yoke....
I have and never had any problems.
We did my dad's Astro van 6 years ago and it now has 190k with no problems.
Also did the same to the ole 85 chev plow truck 10 years ago with no problems since, and that thing works hard pushing snow!
Old 12-10-2005, 09:10 PM
milner's Avatar
1994 ranger does have inside clips, that you have already found out. if you have replacement ones with outside clips, they are wrong.like basementhotrod said, use a small chisel and hammer to get them off. lay the open end of the crosser in a open vise and tap on the yolk with a hammer. be careful not to damage the yolk.if it is stuck, try hitting the end cap. this will usually loosen the rust. good luck.
Old 12-21-2005, 08:33 AM
Last journal entry: ok im on to my next big dream beast
take the u-joint out i just put it into a vise and find a socket that is barely smaller than the caps and tap it a time or two then use the screwdriver or chisel method use safety goggles and just give it a good swing it should pop right out then rotate 180 in the vise and tap the other cap the first side should start coming out of the other side then this will give you more than enough room to get the other clip off the other side and finish driving it out fot the opposing side rinse and repeat LOL
as far as the driveline youre having trouble with you will have small u bolts or small caps over the u joint holding it inplace remove the four bolts and then they usually just slide out of the transfer case on the front side of the driveline good luck
Front Ball joint ... PICTURE bg Suspension - Brakes - Steering 17 04-16-2005 01:24 AM
Do I need a rag joint? americanLT1 Suspension - Brakes - Steering 5 11-02-2004 12:31 PM
Replace Steering U joint Dave E Shank Suspension - Brakes - Steering 1 08-13-2004 05:51 PM
rag joint hagood Suspension - Brakes - Steering 1 06-21-2004 08:21 AM
79 Suburban Ball Joint change Help!!! mr_chickenhead Suspension - Brakes - Steering 2 01-09-2003 08:08 PM
