U joint removal tool-How to use - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-24-2011, 11:19 AM
Ball joint service tool. Basically an overgrown c-clamp with a hole in the end for the cap to come out of. You can pick the up at NH, Harbor fright, ext. for cheep and makes the job a cinch.
  #17 (permalink)
Old 06-24-2011, 09:50 PM
sbchevfreak's Avatar
Licenced Automotive Technician
On a steel shaft, easiest way is a large bench vise, and a 3 lb hammer. On the rear joint, remove the 2 loose caps, and place the cross across the jkaws of the vise. Then srike the yoke just ahead of where it is welded to the tube hard, several times. The "top" cap will be pushed up and out of the yoke. Flip it over so the other captured cap is now on "top", and repeat procedure.
To install, use the vise jaws like a manual press to squeeze the caps in one at a time. I like to put a small swipe of grease on the needles so they don't fall out so easy.
Learned a new tip about tie rod and ball joint removal DaSouthWon Hotrodding Basics 7 01-07-2009 02:16 PM
Best tool for floor pan removal? Bilko Body - Exterior 5 12-29-2006 10:53 PM
U-joint removal oldsmo Transmission - Rearend 11 03-21-2006 02:01 AM
u joint removal adrock430 Suspension - Brakes - Steering 7 12-21-2005 08:33 AM
u-joint removal johnnymopar Transmission - Rearend 6 01-03-2002 12:42 PM
