U joint removal tool-How to use - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2011, 08:51 PM
impalaman63's Avatar
How do you use this U joint removal tool?
http://www.amazon.com/U-joint-Puller.../dp/B002EWX49G
Need to change the U joints (3) on my 1963 Impala.
Old 06-24-2011, 06:43 AM
T-bucket23's Avatar
Wiki Edits: 26
Never used one of those. I have always either used a press, a vise or a hammer. All three with a couple of sockets. If you are unsure how to do it, for less than the price of that tool you could probably have a garage do them for you. For anyone who has done them it is an easy task. The key is to keep the needles from falling over. The rear is usually the easiest, the front and centers are a little more challenging
Chet
Old 06-24-2011, 06:49 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
It would be interesting to see how it works.
delawarebill's Avatar
how to use it ????
thats a good ???... the feet don't look like there is mounting holes to keep it on the bench.. if u have a vise at home and of a good size u can use that just as well. small socket at one end to push through and larger socket on the other to allow the other bearing to fall into it... if u have a garage to work on the car and don't have a nice sized vise u need to get one then u'll always have other uses for it...
Old 06-24-2011, 08:12 AM
I think this would work much better and cheaper.
What do you think?
Old 06-24-2011, 08:34 AM
PATH=$PATH\:/usr/local/bin ; e
if you are looking for cheep, down and dirty simple. Just get a large C clamp that will work just fine, btw use the socket.
Old 06-24-2011, 08:39 AM
NEW INTERIORS's Avatar
Set no limit's on yourself
What do you think?
That will Work, But be very careful,,, That is a lot that could fly... T-bucket23 explain's the best way to do it.. But your way would work,, Just be careful..
Old 06-24-2011, 08:42 AM
Also soaked it in ATF fluid over night. I tried C clap and heat no luck.
Old 06-24-2011, 08:43 AM
If you take the big socket and turn it upside down on the floor, And take the little socket in hit it with a big hammer.. I think it would be a little easier.. And a little more safer..
Old 06-24-2011, 08:44 AM
Don't use heat.. And make sure there is no clip's holding it in..
Old 06-24-2011, 09:03 AM
I think I would try some penetrating oil, ATF is not good for that. No heat, I agree checking for clips good idea. When I say C clamp I mean one 8 inches and heavy.
Old 06-24-2011, 09:59 AM
T-bucket23's Avatar
Wiki Edits: 26
C Clamp probably wont have enough leverage. Did you remove the locks, some are obvious and some are not.
Chet
Old 06-24-2011, 10:05 AM
Locks removed. 48 year old U Joint.
Old 06-24-2011, 10:31 AM
T-bucket23's Avatar
Wiki Edits: 26
Sit in on a strong bench or the floor, Put a large socket under the joint and hit the top with a socked and a 3 LB hammer. It is helpful if you have a helper that can hold the shaft from moving around on you.
If you cant get them to go, bring them some where that has a press. I have never had to press them out, I have used a press but it was just for convenience.
Chet
Old 06-24-2011, 10:32 AM
T-bucket23's Avatar
Wiki Edits: 26
Can you post a picture of the shaft and your removal setup
Chet
Learned a new tip about tie rod and ball joint removal DaSouthWon Hotrodding Basics 7 01-07-2009 02:16 PM
Best tool for floor pan removal? Bilko Body - Exterior 5 12-29-2006 10:53 PM
U-joint removal oldsmo Transmission - Rearend 11 03-21-2006 02:01 AM
u joint removal adrock430 Suspension - Brakes - Steering 7 12-21-2005 08:33 AM
u-joint removal johnnymopar Transmission - Rearend 6 01-03-2002 12:42 PM
