U-Joint Yoke Nut Rusted/Frozen - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2003, 01:39 PM
PrimaDude's Avatar
Post U-Joint Yoke Nut Rusted/Frozen
I am prepping a 12-bolt housing for restoration and I am trying to remove the u-joint yoke nut that is on the rear-end. I just can't get it off. Does anyone know off-hand if this nut has a reverse thread?
Old 03-15-2003, 01:53 PM
BOBCRMAN@aol.com's Avatar
Post
if you are referring to the pinion nut, the big one, the thread is a standard fine thread, but it has tension on it from the bearing preload and a crush spacer, you will need a large impact wrench. if you are having trouble with the u-joint bolts they are also std fine thread, use heat.
[ March 15, 2003: Message edited by: BOBCRMAN@aol.com ]</p>
Old 03-15-2003, 02:08 PM
PrimaDude's Avatar
Post
Thanks for the input...
