U-pol Raptor Liner/ Acid Etch #8 question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2012, 12:04 PM
Mach1460's Avatar
Last journal entry: Project 92' Eddie
I ordered the Raptor liner from U-POL for the floor of my bronco project. I have searched here and a google and couldnt get a solid answer so here goes.
The Raptor Liner kit says to spray acid etch over any bare metal before applying the Liner. ( I dont physically have the kit yet, its on the way... this is what ive read)
Well ive spent a day scuffing the floor/bed of my Bronco with 40 and 80 grit paper and have bare metal showing on the edges of the floor (pic). I have a half gallon of acid etch #8 from a previous project (bought wayy to much) and was wondering if I can just spray the entire area with acid etch 8 that will be lined with the bed coating?? Basically im asking if the acid etch 8 will adhere to the "scuffed" floor paint from the factory?? -OR- does it need to be applied to bare metal only??
Old 08-23-2012, 07:28 AM
deadbodyman's Avatar
Wiki Edits: 11
it'll stick to properly preped painted surfaces (sanded and scuffed),be sure to use a wax & grease remover first.
Acid etch vs sanding-- Help! Mach1460 Body - Exterior 7 07-17-2011 05:53 AM
Acid Etch Primier on Filler jjhabing Body - Exterior 8 03-09-2006 07:16 PM
Raptor / Raptor jr 700R4 bootshd Transmission - Rearend 8 12-01-2004 04:39 PM
Proper uses for acid etch primer? Rocket1 Body - Exterior 7 09-09-2004 07:50 PM
Metal Etch Better than Self-Etch Primer? unstable Body - Exterior 4 03-14-2003 11:04 AM
