U Weld Em Motor Mount Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2010, 03:34 AM
I have these u weld em mounts and I'm unsure of how they would go together.
I'm thinkin I am missing a couple of the triangular hunks.
I'm not sure where they came from but might be a place called Ply-Do. They are not in operation after the death of the owner, so I can't ask there.
Any help by way of an assembled pic would be great
Old 08-07-2010, 05:34 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Welcome to Hotrodders.com Glad to have you with us.
Your missing some gussets, (make some or follow the link) they weld on the underside of the piece you have
& then to the frame to achieve the correct height for the mount to bolt to the engine.
Rich
http://www.aa-mfg.com/pdshop/shop/item.aspx?itemid=37
Old 08-07-2010, 07:42 PM
life is a temporary assignment
You weld the One gussets right down the center of the one's on the mounts..Under neat.. You want to make a T.. You decide with one work's better for your set up..The big ones, Or the little ones.. I try to use the bigger ones.. You don't have anything missing.. Hope this helps..
This is two different ways you can do it..
ID:	47231   Click image for larger version
Old 08-07-2010, 07:47 PM
Thanks guys, that helps alot!
Old 08-07-2010, 10:02 PM
I played with your picture a little.. Hope you get the picture...
Old 08-08-2010, 04:34 AM
Crystal clear now THANKS!!!! This type should be OK for street use on a mostly stock 350 I think.
Old 08-08-2010, 03:32 PM
327NUT's Avatar
It will work just fine on most builds, this is the same type of mount used on most street rod chassis.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
Hotrodders Guidelines -- READ ME Jon Hotrodders Site Suggestions and Help 0 06-14-2003 05:07 PM
