Ugh Highperformance engine parts?????
hi im from vegas I paid a guy to throw a new engine in my 92 chevy while I was moving to cali, the guy stops wrking on it half way thru and the only information I get is oh its a high performance engine. I get my truck shipped out here half done only to basically tear it down again. the engine block says 5.7 on it for sure with some casting numbers of 638 n or something like that. We weren't getting any spark from the distributor so I went ahead and replaced Ignition coil, Cap and rotor, and Ignition module we gt our spark. then we thought hmm well maybe were getting the firing order wrong but the order is cast on the top of the engine so that wasn't it we realized we don't have any compression in the engine at all, then we also figured the timing chain might be off or wasn't set. Come to find out I Have a high performance timing gear drive. Now im not even sure what cam I have if it might also be high performance. On top of that im starting to question *** engine were even working on, getting any cast numbers off this thing is hard a mission in it self. HELP!!
Ok, lets start with the basics:
This is a 1992 Chevrolet, but what model? What fuel delivery system? What transmission? Not to be rude, but the term "high performance" really doesn't mean squat. We need to figure out exactly what you have and what your expectations are for the vehicle before you can get some help. Head casting numbers should be underneath the valve covers, we'll need those too. If you have the casting from the block, this website should be able to tell you want it came from: Small Block Chevy Engine Block casting and code identification You don't sound too sure it's a 350 towards the end of your post. |
Can you get the cast numbers off the bell housing area on the drivers side, and the stamped numbers on the block pad, in front of the passenger side head?
You sure is has a gear drive? If there's absolutely no compression, check valve adjustment as a starting point, then go to cam setup/alignment. Edit: Looks like Valkerie types faster than I do.
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
The first thing I would recommend (along w/the others here) is to readjust the valves. Here are instructions. If you STILL have no compression, let us know. |
| which...Piston Rings ? ? ? ugh... | rockher_man | Engine | 3 | 12-05-2009 07:45 AM |
| ugh new motor and more issues | Boosted89RS | Engine | 2 | 04-22-2008 09:40 AM |
| Corvette forum, Ugh! | roger1 | Body - Exterior | 4 | 07-10-2006 09:13 PM |
| ugh, another computer problem | ChevelleSS_LS6 | Off-Topic | 9 | 11-17-2005 08:58 AM |
| Ugh! More sanding! | Weimer | Hotrodders' Lounge | 5 | 06-07-2005 09:35 AM |
