UH OH, Ring Around the Body Filler - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2004, 02:13 PM
'77 Regal's Avatar
New Member
I have a quick question, I needed to use a little filler for a crease on my car, so far the repair seems great, expect this ring around where the bare metal, paint and body filler meet. I've tried sanding this area down, but to no avail. Any suggestions?
If this helps, it kinda reminds you of the ring in a tree.
Thanks!
Old 06-25-2004, 03:15 PM
roadmouse's Avatar
I'm not completely sure if I understand you right but that sounds like the paint is reacting with the filler.
if thats the problem you have you are in deep *******!
only thing to do is get it off again, spray a sealer product on it and start all over again.
Old 06-26-2004, 10:53 AM
dinger's Avatar
You need to feather the area with primer or spot putty or both. Blend in where the bondo meets the old paint. Dan
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 06-26-2004, 08:31 PM
'77 Regal's Avatar
New Member
Thanks alot, I did that and it turned out beautifully!! Thanks again.
Old 06-27-2004, 01:02 PM
Danno's Avatar
New Member
Last journal entry: Time for some tunes.
feather it out good, then if you still concerned about it. Us a high build primeir. Get's rid of the little imperfections in the body. Really great stuff, makes life easier. I used it on my pickup. http://www3.sympatico.ca/den.shephard/First.htm
