Prouect89, why not try this on a panel, maybe the trunk lid, and compare the results to the Rustoleum. The automotive paint will be more expensive but will be permanent and save a lot of work later. It will be fuel proof, durable and permanent. It can be brushed, rolled, or sprayed, as long as it's not a metallic. You can reduce it to the consistency you need. All this talk of rolling, sanding, buffing, and then having to strip it off in the spring is making me tired just reading about it.....
Current pricing on SPI epoxy primer is now $20.22 a quart when purchased in the gallon units. the cheap stuff is that much so why would I use anything but the epoxy primer? H'mmm
Sam
Some peel but good shine. The acoustic tile ceiling doesn't help!
Should look good after wet sanding/buffing. Which paint is this again?
the black is the rustoleum mixed 50/50 with mineral spirits, i wetsanded that coat and just hit it with another coat not to long ago, this next coat is looking even better. just wish i could keep the dust and dirt off the paint while it was drying, but im doing this on my front porch so i just have to deal with it looks liek i still have some sanding scratches so when this new coat dries ill wetsand it and hit it one or 2 more times and it should be done. |
but im having alot of fun making it look as good as i can,and the more i do it the nicer its comming out. so instead of just getting it on the car im taking my time and going to get it to look as nice as i possibly can. so far its been a pretty fun learning experiance,and looking foward to getting more of the car done.got a single coat on a spare rear bumper cover i have and the results are pretty damn close to the hood |
hoods done except for a final wetsand/buff which im going to wait 2-3 weeks so the paint had more time to cure
but it looks good as is except for were my friend dropped the ratchet on my hood its a 3-5ft paint job for sure ![]() ![]() ![]()
Hmm
Rustol-leum very nice and very cheap, hmmmm
got the spare rear bumper cover almost done needs one more coat after a quick qwetsand , ill post some pictures of that tommorow when i get out of work if its warm enough for me to get it on the car
I have done the following with great results, on one of my projects, I stripped car panel by panel to bare metal, used the phosphoric acid treatment, and then shot on Rustoleum primer with my elcheapo HF gravity fed HVLP gun. The primer was reduced with Dupont Medium Speed Acrylic enamel reducer, about 25% reducer 75% primer, 3 coats, allowing primer to flash between coats.
After a curing period of about 3 weeks, I then used all fillers, and 2k high build urethane primer/surfcer, this was blocked , then I used an industrial high gloss alkyd enamel to topcoat, mix ratio 8 parts paint, 4 parts reducer, 1 part hardner, 3 coats, allowing to flash between coats. This was near 3 years ago, paint is super shiny, no peeling, no issues, and very durable. Last year I painted the Fulton Visor, with a different lot of paint, it was dead-on match, and the older paint on the car, is just a shiny. I have to to cut and polish this paint job, it is quite decent for a super low budget paint job. |
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain |
sorry i havent updated in a few days but im a lil pissed at myself and the car.
i spent 15 hours preping and painting the spare rear bumper cover i had and went to install it on the car, just to find out its the wrong bumper cover. it was for an 82-84 without ground effects,im mad at myself for not catching it and just generally pissed off at the car right now so its been sitting, havent done a thing except remove the side mouldings off the doors and fenders. but ill get back to it this weekend prolly the hood has been snowed on iced up washed off etc and it still looks good |
| Currently Active Users Viewing This Thread: 4 (0 members and 4 guests) | |
| rustoleum vinyl paint | HelmetTester | Interior | 8 | 02-11-2012 04:43 PM |
| Roller/Rustoleum Paint Job and Door Jambs/Trunk/Hood | deleteall | Body - Exterior | 15 | 06-23-2010 04:18 PM |
| Budget paint | Chevyguy89 | Body - Exterior | 5 | 11-21-2008 04:44 AM |
| black rustoleum paint in egine bay?? | mrobby440 | Body - Exterior | 10 | 05-19-2006 07:06 AM |
