Boy!!!! Your leaving yourself wide open for this...
oh i know i am, but ive read all the threads on various sites about this budget paint job, and for what im doing it fits the bill perfectly, i only needs it to last the winter to protect the body from the road salts etc till i can restrip the car and have a real paint job done.
the car was supposed to be finished 2 months ago and gone out to paint already but it took me longer then expected to get the twin turbo motor built and running, and i really dont want my car painted with exspensive paint just to be driven around in the snow and salt without having enough time to harden/cure. so for me this was the perfect alternative for the winter season |
Reminds me of this:
http://blogs.hotrod.com/rustoleum-69...tips-3819.html I found this link on another forum thread (it was posted by General Martok). what do u think of Rust-Oleam |
Rustoleum saved the day
We will see more Rusto- car paint jobs I suspect
I hear ya !!!! This topic was here more then once in the past and didn't go over to well..... I hope you have some tough skin... Good luck... Look like it came out OK..
To someone like myself (not a painter) it seems that doing this in an epoxy primer would also last through the winter but wouldn't require stripping before the rest of the finish was applied. It wouldn't be shiny like the rustoleum, but is a couple months of shiny instead of satin worth having to entirely strip it?
This seems like a no-brainer, so what am I missing? |
i can take the good with the bad no problem. the more the paint dries the more it flatens out and the more glossy it gets, i honestly didnt expect it to look like it does, im pretty impressed with it but its not something i will leave on the car.also it would look better if i had better lighting and i didnt forget to close my heater vent on the porch when i started the first coat since it blew some dirt/dust out of the vent onto the hood when the heater came on . its nothing that wont wetsand out before the next coat though. i have 2 gallons of a nice deep metalic blue and silver sitting here for the real paint job this spring 1 gallon of each. |
had i had the right stuff to spray the car id prolly have used an epoxy primer and sealer on it instead |
No tools IS a problem. So does that mean you're going to roll the "good stuff" come spring?
$60.00 worth of paint and hundreds of hours of labor. They never mention how much labor is involved. Quit while you are ahead. Rustoleum can stay soft for months. Wait until you have to sand the car down again when you put some real paint on it and you will see. For another $40 you could put some cheap urethane on it that will last for years. Take a guess how much sand paper you are going to go through when you have to sand it down for real paint.
You know why you never see them mentioning using a spray gun when putting on Rustoleum from the quarts or gallons? Load some up in a spray gun and give it a shot. You won't have any control on how the paint will go on. You can get sags and runs. Then you have soft paint that needs to be removed and you will be back to square one. It will clog your sand paper fast.
You can go right over the top on the paint you have on your car now if it's not too bad. That won't be happening once that Rustoleum is on the whole car. You can find AE or Urethane all day long for less than $100 if you want cheap paint. You can rent a paint booth. The difference is you are only spraying it on one time, not applying it over and over again.
| rustoleum vinyl paint | HelmetTester | Interior | 8 | 02-11-2012 04:43 PM |
| Roller/Rustoleum Paint Job and Door Jambs/Trunk/Hood | deleteall | Body - Exterior | 15 | 06-23-2010 04:18 PM |
| Budget paint | Chevyguy89 | Body - Exterior | 5 | 11-21-2008 04:44 AM |
| black rustoleum paint in egine bay?? | mrobby440 | Body - Exterior | 10 | 05-19-2006 07:06 AM |
