ultra bell housing - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2004, 11:05 AM
New Member
ultra bell housing
I broke my bell housing on my th350 and am looking for some alternative to fix it. Has anyone seen or used the ultra bell from jw performance. I read about it and it seems to be what I need, but has anyone used one or seen how it mounts up to the tranny.
Thanks
Old 07-31-2004, 12:55 PM
Had a friend get one.
Fairly expensive $$$...................but he needed one. He had to saw off the old bell and then bolt the new one to the transmission. His was a Powerglide with a BUNCH of HorsePower.
He had broken 3 or 4 stock PG cases.
IF you are not pushing a ton of power and broke your case,,,,,,,,,,not with HorsePower...........it might be less expensive to replace the Turbo 350.
Old 07-31-2004, 07:37 PM
New Member
I would just replace the th350 if it were just a stock one but this one is built by hughes performance and was pretty expensive. Also the engine is pushing over 400 hp+torque so I am thinking of going with a little stronger bell housing or just transfering the guts of the tranny into a new case.
