ultracool - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2011, 04:35 AM
ultracool
Just wondering if anyone on here has ever used a profuct called ultracool? I seen it advertised in Streetrodder and it's supposed to lower your rides temp by 30 degrees. YOu just mix it in with the coolant. Thanks
Old 10-27-2011, 09:27 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
http://www.zirgo.com/catalog/Advance...Additive/SCOOL
Never tried it.
Semper Fi
Old 10-29-2011, 12:01 PM
Landshark928's Avatar
FrankenPorsche
Most of the radiator additives work well, but not 30* worth. Water wetter is what I use with straight water here in Florida. It drops my temp about 10*, not the advertised 30*. With a 50/50 mix it would do less and not be worth the $8-12 IMO.
Basically it breaks the surface tension of water and allows it to have a smaller laminar flow boundary allowing for better heat transfer.
