ummm...CRAP---Piston Eyebrows / Bigger Valves - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2004, 06:34 PM
unstable's Avatar
Murderator
Last journal entry: Brackets, Stories and the future
I've got my heads in the shop now, getting bigger valves 2.19/1.88 from 2.06/1.72
My plan was to leave the shortblock together...but I was reading I may have a problem with the pistons now...man wtf?!
Old 06-08-2004, 06:48 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
clay 'em.
Old 06-08-2004, 07:20 PM
unstable's Avatar
Murderator
that's the only thing TO do. Just not something I had thought about because I'm a *******.
Old 06-08-2004, 08:53 PM
Not as much of a ******* as you're making yourself out to be. You figured it out before you bolted it together and turned the key.
Old 06-08-2004, 09:19 PM
ratlover's Avatar
here's a pic of how much clearance I have with .525" lift and 2.06" valves. It amounted to .160" valve face to piston an about
1/3 of that to the side. (.053) you may just squeek by, but don't take my word for it. Check it with clay as well to be sure. Someone else will have to give you the tightest rec. clearance as I do not know what that would be. I also decked the block .020" before taking that measurement.
Name:	test vid&pics 001a.jpg
Old 06-09-2004, 08:30 AM
unstable's Avatar
Murderator
I've read about the procedure for checking...just not exactly sure what I'm doing. This will be a first for me.
I know you take the clay, about 1/4" thick, and put it into the eyebrows. Then you bolt the head on, and rotate the motor over to make the valves open.
This should leave an impression on the clay. But after this, I'm not quite sure on how to measure it, or what is acceptable...etc. etc.
Oh also, why I'm nagging about stupid stuff. Does anyone have a recommendation on a hot street cam for this thing? I'm goign to be running a standard tranny, headers...not sure of my rear gears ATM. I will run a dual plane intake. I'd like something pretty lopey, that has plenty of strength in the low RPMS so I can goose it up a bit. I like that mean sound with a rough idle.
Old 06-09-2004, 08:46 AM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
Suggested from a good source (30 machine shop guy) what do u guys think?
When i was bolting together my mopar the machine shop guy (who just got done doing my machine work and selling me slugs, pump, rings, pins, you name it) said to bolt the head on with about 20 ft lbs of torque in the normal, uniform pattern WITHOUT using the head gasket, then measure the piston to valve clearance. This because apparently (and maybe also because I was using a roller cam) at higher RPM the lifters have a significantly increase kinetic energy (make sense) and it causes the valve to lift some times .030 thousandths beyond normal spec lift! Also, your exhaust valve can expand (think he said something about that). Anybody heard this advice?
K
Old 06-09-2004, 09:17 AM
unstable's Avatar
Murderator
I was reading the procedure on IskyCams.com:
http://www.iskycams.com/camshaft.html
It walks through the entire process...there's another way where you use a weak spring to check. I've just never done this and I don't want to screw it up. lol
I wouldn't imagine that I should have a problem. I have flat top pistons. I'm just thinking about the reliefs that are cut into the pistons...if they are too small or whatever...apparently they are there for a reason right? lol. argghghghg, I'm going to blow something up I'm sure of it.
Old 06-09-2004, 09:41 AM
ratlover's Avatar
As you can see in the photo, you cut a section of the clay away, and I used the but end of a vernier caliper to take depth measurements at various points. You can also use a depth mic if you have one. With the flattop pistons, you have to watch how much cam you select as you will need more compression to run a long duration cam. The motor would have a great sound at idle, but in reality be a real dog. I chose a 268h comp cam and was pretty happy with the idle characteristics and power with the flatops.
Old 06-09-2004, 12:52 PM
E.T. divided by $ spent= Speed
I squirt WD-40 on the top of the clay(after its stuck to the piston)so that the valve doesn't stick to it and pull it off the piton and into the vlave seat.
Use a regular machinest's ruler to measure the impression in the clay.
Old 06-09-2004, 01:07 PM
i had that feeling too.
take your time, do it right, and it will not blow up.
if i can do it, ANYONE can.
Old 06-09-2004, 07:17 PM
ratlover's Avatar
think of it this way. you currently have 2.06" valves, you switched to 2.19". That's a difference of .013" divide that by two and you have the amount of .0065" difference relative to the valve reliefs.(not a huge amount) assuming that your block has not been decked, I think you might have enough room if you base your camshaft selection relative to the amount of clearance that exists with your present cam. You could also try a thicker head gasket in the worst case scenario. (or lower lift cam.)
Old 06-09-2004, 08:37 PM
unstable's Avatar
Murderator
Mr. Ratlover...oh great master of understanding these things...lol.
I have no idea what cam is in that thing now. I was planning on replacing it though.
Now, here's where it gets tricky. Help me here..
If I measure the clearance with the cam I have in now...is there a way of determing how much lift the current cam is? to where I can say "hey I still have room to move up...or hey I need to move down to something smaller"?
I'm perplexed. I tore these heads off and I feel like a *******. I had no idea there was this much involved. I'll get through it though...with everyone's help. No better way to learn than to actually do something...right?
Old 06-09-2004, 11:08 PM
ratlover's Avatar
I appreciate your flattery, but I am just trying to help. I make no claim to be the all knowing chevy guru type. The easiest way is with a magnetic base dial indicator. They are great for measuring all kinds of things so it's not just a one use dust magnet. If you put the plunger on the lifter or cam lobe it will read the amount of travel in .001" of an inch increments. you would have to multiply that by your rocker arm ratio in order to get net lift.(1.7 on a big block usually-stock ratio) you can cheat if all you require is an approximation. take a vernier caliper or machinists rule and measure the shiny part of the pushrod where the pushrod guide rubs, and that will give you an idea or get you in the ball park. This is where degreeing a cam is very useful if the duration is also unknown. there's a thread recently started, but not many people there saw the use of this procedure. They were speaking of verifying known cam timing however. The dial indicator can also be used for measuring crank shaft endplay, true tdc, backlash .. the list goes on. I would also look on the cam for identifying marks which may save you all this measuring also. look on the back of the cam on the distributor end.
Name:	cam degreed 0040.jpg
Old 06-10-2004, 08:19 AM
unstable's Avatar
Murderator
I've been reading up on cam degreeing but much of it sounds pretty confusing...only because I've never done it before. I come from the school where, I can handle the procedure, but it's nice to have someone around or available to tell me if I messed up.
know what I Mean? I could get all the numbers and think I'm Kosher--when I'm actually not.
I'll post back when I'm further along. Heads are in another state right now getting worked over.
