Unable to add new entries into my journal - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders Site Suggestions and Help
Old 07-29-2005, 10:59 PM
Sly's 53 Suburban's Avatar
Last journal entry: Built a shop to expedite building my toys
Jon,
I am unable to add new entries to my journal. I delete all my cookies and am able to log in. I can log in and see the project journals as well as post in the forum, but I can't log in and add to my journal. When I log in I can't see the project journals page, I keep getting the error message problem with project journal data base an email has been sent to Hotrodders to alert them of this problem. I delete cookies once again and am able to see the project journals, but again upon login I get the error message.
Old 08-01-2005, 06:26 PM
Does this post make any sense? I've tried to login from two locations in Utah and now from Idaho and still unable to see the Journals after logging in. If it's just me I'll give you my login password and see if you are able to log in as me. I have deleted cookies and still the problem remains.
Am I still here
Old 08-02-2005, 10:22 AM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
Post some exact urls that are causing these problems, and I'll check it out.
Old 08-02-2005, 08:11 PM
Jon,
Thanks for responding. Here is the login URL.
http://hotrodders.com/forum/journal.php?
Old 08-03-2005, 07:49 PM
Jon's Avatar
Jon Jon is offline
Wiki Edits: 7314
OK, please PM me your password.
Old 08-04-2005, 12:50 PM
Jon's Avatar
Jon Jon is offline
Wiki Edits: 7314
Fixed.
The problem was due to the single-quote character in your username. It was causing a conflict with the journal login mechanism. Completely my fault, sorry for the delay in replying to your problem. I had thought that it was due to an error on your end, and you would eventually be able to login. I've fixed the issue, and now users with the single-quote character in their username should not have a problem.
I was able to properly login to the journal system as you after the fix. Please double-check from your end to make sure that it works.
Old 08-04-2005, 02:08 PM
Jon,
Back up and working. Your awesome.
Thanks
Poll: Do you miss the journal comments? grouch Hotrodders Site Suggestions and Help 29 06-22-2005 08:58 PM
Cant add new entries to journal WakBordr7387 Hotrodders Site Suggestions and Help 12 05-07-2005 08:19 AM
Journal now shows 2x the entries Jon Hotrodders' Lounge 0 03-29-2005 02:07 PM
Can't add anything to my project journal clinthart Hotrodders Site Suggestions and Help 1 03-11-2005 12:03 PM
100 Entries in Project Journal !! Beenaway2long Hotrodders' Lounge 10 07-01-2004 08:00 AM
