Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Unable to separate head from block due to head gasket sealer
Old 02-01-2011, 11:50 AM
hotrod389 hotrod389 is offline
machinist & fabricator
if i were you, id try using a leak down tester!!!!
fill one of the end cylinders with air pressure, make sure the valves are closed. 100 psi @ least.
then try prying the head off again.
