Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Unable to separate head from block due to head gasket sealer
Old 02-01-2011, 06:07 PM
CJ_1080's Avatar
CJ_1080 CJ_1080 is offline
known to do dumb stuff!!
Originally Posted by h0trod389
if i were you, id try using a leak down tester!!!!
fill one of the end cylinders with air pressure, make sure the valves are closed. 100 psi @ least.
then try prying the head off again.
Never thought of that, that's a good one! I've had a few heads be complete boogers. Usually because the tractor or motor I'm working on hasn't moved in 40 + years.
