Unable to separate head from block due to head gasket sealer - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-02-2011, 09:54 AM
jeffery wells's Avatar
wow, talk about a stubborn head, i to have done used the handle of a hammer, it was on a lawn mower, but still. DON'T USE ANYTHING THAT WILL DAMAGE THE HEADS, make sure the tool you are using is softer then what you are prying on, learned that one the hard way and had to get new heads.
  #17 (permalink)
Old 02-02-2011, 11:20 AM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Originally Posted by 1971BB427
I've used the cranking engine (with plugs in the head!) often, but if this is an overhead cam engine it should not be done. It only works with engines that have the cam located in the block.
Why couldn't it be done on an OHC engine?
  #18 (permalink)
Old 02-02-2011, 11:28 AM
1971BB427's Avatar
Because you've got a chain or belt that attaches the cam to the crank. If you remove that it wont open and close the valves and the piston may hit the valves. If you leave it hooked up it may damage the head, sprocket or belt when it comes loose.
You could pull the rocker arm ***. and the cam belt, and then do it, but that's the only way to do so with an OHC engine.
  #19 (permalink)
Old 02-02-2011, 01:12 PM
success @ separating the head from the block
The problem was gasket sealant and 14 studs.
I used air pressure through the spark plug holes, and was able to verify the head was loosened. This also partially separated the gasket from the head, and with a little perseverance, the hoist was able to pull it off.
1st time I've used the forum, and want to thank you all for the help.
Aluminum heads, iron block, what head gasket? 383SBC Engine 3 09-21-2010 07:45 AM
cracked head or head gasket???? onebadmerc Engine 12 12-04-2008 12:10 PM
400 small block compression and head gasket question 19nova72 Engine 2 07-07-2005 09:49 PM
oil on head bolts and head gasket bullheimer Engine 7 05-25-2004 04:50 PM
Removing Head Gasket from Block sb72elcamino350 Engine 14 03-10-2004 06:53 PM
