-   -   Under Coating (http://www.hotrodders.com/forum/under-coating-77758.html)
R. Builder 01-02-2006 08:29 PM
Under Coating
I have a 53 Chevy 150 2 dr. sd. I need to clean the bottom side of the floor pan. What is the best method of removing the old undercoating? I have the body on a rotisserie.
poncho62 01-02-2006 08:33 PM
Propane torch to soften it....and a scraper.
R. Builder 01-02-2006 08:44 PM
Thanks for the tip. I had hoped for something easier but I'm no stranger to getting in the dirt. I had though that I might use a high pressure washer and see if that would blast it off. It is cold out side now and that would make it more brittle now.
crashtech 01-02-2006 10:13 PM
Wear a respirator, Those fumes can be nasty!
R. Builder 01-05-2006 05:31 PM
I solved my under-coating problem. I used an hammer with a chisel blade. I didn't use a lot of pressure as to cut or dent the floor pans. I vibrated most of it off in fairly large pieces. Some areas I had to use more of a slanting method. It was a respirator job with ear plugs but it took me only one day or about 6 hours of steady work. The results we better than I had expected. Thanks to all who had thoughts on this matter.
kenseth17 01-05-2006 08:10 PM
I had to strip the underside of a hood to paint, and whoever painted the car who knows when before instead of properly painting the underside the new color or using a black out paint, thought undercoating was the quick and dirty way they would do it. What a mess. The way that ended up working the best for me when I tried taking it off was using kerosene outside in a ventilated area and scraping with a putty knife. Still real messy. Once the bulk was cleaned off, I finished up using lacquer thinner and sanding.
