Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Under floor master cylinder
Old 05-10-2013, 08:00 PM
rustman rustman is offline
Hello. I have a power brake master cylinder mounted under the floor. Mine is mounted backwards as I think most are. Both reservoir are the same size. I am running disc's in front and drums in rear. Mounted in that position, is the reservoir closest to the vacuum booster for the front or the rear brakes? I know that normally the big reservoir is for the disc's but as I said they are equal size. Thank you.
Name:	master cylinder (Small).jpg
