Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Under floor master cylinder
Old 05-13-2013, 07:38 PM
RatPin RatPin is offline
Originally Posted by RatPin View Post
I have the same MS and res closest to booster is for front. My problem is no brake pressure bled and bled again. No air in lines but pedal goes to floor with engine running. Nobody seems to have an answer.
After doing some research for my brake problem (see other thread) I have realized that in most diagrams I see that the way they plummed the combination valve is how you described yours. Closest res to the booster is for the rear brakes and the other is for the front.
Someone said it does not matter but can anyone confirm this before I go buying and bending new brake lines to plum it like I described above?
