under floor master-cylinder - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2013, 01:38 PM
another master cylinder question.. its a little different then the one just below. I am getting ready to run brake lines on my 52 chevy, I have installed an under floor dual power master cylinder, I have disc on the front and drum on the rear. I found a pic of how to run the lines with the 2 psi residual pressure valve in the front and the 10 pound residual pressure valve in the rear along with a adj portioning valve in the rear. I'm good with that.. My main question is "Is a combination valve really neccessary with the above set up? The diagraphm I have does not show one. I also have a "T" to put my brake light switch in. Thanks
Old 01-07-2013, 03:21 PM
Irelands child's Avatar
I can't imagine why that 'combination' valve keeps coming up. I'm assuming (scary word) that you are going to be using someones aftermarket brake assembly, most of which use a '70's Corvette master cylinder. That arrangement you described will work - 2psi residual valve in the front, 10 psi in the rear along with the proportioning valve with the brake switch teed off the line.
A couple of comments - a mechanical brake light switch somewhere on the brake pedal linkage will save at least three leak possible places (I'm using the hydraulic switch too). There are two configurations of those switches to make life interesting - lights on against the spring action or with. Then, make sure you plumb the MC correctly - the big reservoir is for the front brakes and you may have to actually cross lines as that MC is now being mounted backwards from the usual OEM configuration. Some aftermarket versions have that fixed though with two sets of outlets. Also, make sure that the MC doesn't have a check valve built in - some OEM versions do.
A note - that configuration you described is pretty close to what I have on my '31 Ford though I do have 4 wheel discs - and it has worked well for several years
Irelands child
Floor mounted Master cylinder siwel Suspension - Brakes - Steering 1 12-02-2011 09:48 AM
master cylinder wayneooo Suspension - Brakes - Steering 1 09-19-2010 02:32 PM
master cylinder 87MonteCarloSS Suspension - Brakes - Steering 2 09-04-2009 07:32 AM
mounting master clyinder under floor, how to locate? 427v8 Suspension - Brakes - Steering 6 02-20-2009 02:28 PM
Master Cylinder smeech Suspension - Brakes - Steering 2 07-15-2005 06:34 AM
