Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Undercarbed using Strombergs?
Old 09-15-2006, 08:14 PM
matt167 matt167 is online now
Wiki Edits: 31
what about a 2x4 bbl intake using the vintage speed adaptors, making 4 97's. run a progressive linkage between the 4bbl carb base adaptors, but make the 2 carbs per carb base linked togther, so it acts as 2 340 CFM 2bbl carbs.
