Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Undercarbed using Strombergs?
Old 09-15-2006, 11:28 PM
ChevelleSS_LS6's Avatar
ChevelleSS_LS6 ChevelleSS_LS6 is offline
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
or go for a 3x2 setup; unless the 460 is to lug around no higher rpms than that most diesels are well familiar with, the strombergs seem too small considering it's only 340 CFM.
I'd go with otherMatt's suggestion of setting it up as dual 340cfm 2bbls; that should be good to run it to 5000 or so, which is about all a stock 460 is good for- any higher and it'll need head work to take advantage of it.
