-   -   Undercoating (http://www.hotrodders.com/forum/undercoating-49.html)
Chadwick 12-18-2001 07:13 PM
Undercoating
I have some undercoating on my 1963 nova. I was wondering which product works best to take it off??
<img src="confused.gif" border="0">
capn 12-26-2001 06:06 PM
I took off old undercoating on individual panels (undersides of fenders) by heating it up with a propane torch and using a scraper to take it off once softened. Keep in mind I did say on individual panels...You could probably do the same on the underside of your ride but exercise caution not to catch anything on fire or burn anything that does not need to be burnt. I used just enough heat to "soften" the old undercoating. You could also try using a wire wheel on a grinder.
[ December 28, 2001: Message edited by: capn ]</p>
capn 12-26-2001 06:07 PM
roys63 12-27-2001 04:17 PM
[quote]Originally posted by capn:
<strong>I took off old undercoating on individual panels (undersides of fenders) by heating it up with a propane torch and using a scraper to take it off once softened. Keep in mind I did say on individual panels...You could probably do the same on the underside of your ride but exercise caution not to catch anything on fire or burn anything that does not need to be burnt. I used just enough heat to "soften" the old undercoating.</strong><hr></blockquote>
Rerun Rodder 12-29-2001 12:57 AM
I would like to recommend a heat gun instead of a torch. Torches are too easy to overheat the panel and warp it, not to mention the fire hazard.
Wire wheel gets clogged and undercoating tastes bad! ;)
