Undercoating - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2001, 06:13 PM
New Member
Post Undercoating
I have some undercoating on my 1963 nova. I was wondering which product works best to take it off??
<img src="confused.gif" border="0">
Old 12-26-2001, 05:06 PM
Cool
I took off old undercoating on individual panels (undersides of fenders) by heating it up with a propane torch and using a scraper to take it off once softened. Keep in mind I did say on individual panels...You could probably do the same on the underside of your ride but exercise caution not to catch anything on fire or burn anything that does not need to be burnt. I used just enough heat to "soften" the old undercoating. You could also try using a wire wheel on a grinder.
[ December 28, 2001: Message edited by: capn ]</p>
Old 12-26-2001, 05:07 PM
Cool
Old 12-27-2001, 03:17 PM
roys63's Avatar
Post
[quote]Originally posted by capn:
<strong>I took off old undercoating on individual panels (undersides of fenders) by heating it up with a propane torch and using a scraper to take it off once softened. Keep in mind I did say on individual panels...You could probably do the same on the underside of your ride but exercise caution not to catch anything on fire or burn anything that does not need to be burnt. I used just enough heat to "soften" the old undercoating.</strong><hr></blockquote>
Old 12-28-2001, 11:57 PM
New Member
Post
I would like to recommend a heat gun instead of a torch. Torches are too easy to overheat the panel and warp it, not to mention the fire hazard.
Wire wheel gets clogged and undercoating tastes bad!
any link btwn undercoating causing blistering in paint? bullheimer Body - Exterior 2 07-08-2006 09:49 PM
Undercoating a good choice? Fataero Body - Exterior 5 05-28-2006 10:21 AM
stripping off undercoating..what a mess mrobby440 Body - Exterior 13 05-04-2006 07:32 AM
undercoating quality jhenry Body - Exterior 3 12-28-2004 05:11 PM
Old undercoating, remove or no? Pencilneck314 Body - Exterior 21 05-28-2004 11:22 AM
