underdash brake system - clean up firewall - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2003, 04:47 PM
Has anyone used one of those underdash brake systems? Im curious about putting one on my 61 chevy wagon. I'd like to have the firewall totally smooth. Let me know if youve got any good or bad experiences. also what brand and approx. cost..
thanks.
Old 08-11-2003, 02:03 PM
New Member
We use that set-up on our racecar and it works perfect. I'm sure it would work great for you also. It would be manual brakes, but with the right brakes they would stop great. Use remote reservoirs and put them somewhere you can get to them. Wilwood makes them, and you can get all kinds of different master cylinders for them. You can find them at any oval track parts supplier.
Old 08-11-2003, 02:10 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
check the 1st series of snub nose Dodge vans, like this one http://www.fawcett-movie-cars.com/70...gevan275th.jpg they use an angled M/S under the hood because of clearance && they're set up for power disc brakes too..........joe
Old 06-24-2004, 11:36 AM
I have one on my 48 chevy fleetline. you can use power brakes with these. My only problem, because I didn't use a remote fill, is getting brake fluid in there. I'm just in the process of bleeding the system.
about $200 without the master cyl.
