Yeah take it back tell him he's stupid and to give you some centari acrylic enamel or chroma one acrylic urethane and a can of flattener.You can add flattener to it and get any gloss level you want. Chromabase will not hold up.If you get gas or aoil or even wipe it with any kind of cleaner it will come right off.Krylon would be better than chromabase with no clear.
ppg's line is omni is there lowest line, in that line there is a single stage (no clear is needed) acrylic enamel, a single stage acrylic urethane, and also a basecoat clearcoat system (mbc) which like the chromabase needs a clear.
The deltron line is a higher line then the omni, and they also have global. There are a lot of different paints to choose from, depending on your expectations. For something like under hood I would just use the omni acrylic enamel, with a hardener, and if you don't want gloss then add some flattener to the paint like shoddy said. Visit ppg.com and find the auto refinish section for more information on the use of their products. Also you can find some information on the different lines at autocolorlibrary.com. If you have a question about a certain product just ask here, and someone will help you out. You never know what you are going to get at a paint supplier, some are very knowledgeable and up to date on the products and others don't know jack. The store I go to has two guys that have been there since I started in the trade in the early 90's that I can pretty much trust what they say, but they also have some others working there that I really don't trust. There is nothing wrong with dupont either, he just gave you the wrong product for your application. Something like dupont nason, or Centari is a lower priced paint that would work well for underhood, or if matching the exterior and want good gloss and longevity then the chromabase with a clear on top would be a good choice, It depends on your expectations and budget. |
If you're going with PPG I'd get Concept singlestage black and have them mix in the desired amount of flattener. Your jobber will have a mix ratio for different amounts of flattness. Explain to them what you want, eggshell, satin, flat.... The Concept accepts flattener really well and is a very durable paint that's fairly easy to spray. Bob
Concept DCC |
You can use PPG's Concept DCC Urethane single stage Black mixed with their DX685 flattening agent. The mix ratios are listed in the P-sheet P-162. Your PPG dealer will have the P-sheet and it's available online as well.
For instance, eggshell, 20-30% gloss is mixed 1qt DBC, 23 oz DX685, 16 oz hardener. You'll need to keep the paint thoroughly stirred and agitated since the flattener settles out. |
Interesting this comes up, today I actually painted my chevelles underhood area and flat black also. I used some of NAPA's cross/fire acrylic enamel, just told him to mix up some kind of chassis black, or something with lots of flattening agent in it. It was cheap too, only 21.93 for a quart of it, already had plenty of the reducer and hardener at the shop, but they're cheap too, and you dont need much of either, it's a 8:4:1 mix. I took a pic of it, should of waited a bit longer for it to dry and took the pic then, it ended up turning out really nice. But I had to get home, it was 8pm.....past dinner time
flat black
Hey Guys
I have been reading alot about John Deere black. I checked it out and got some further advice theat worked like a dream. Take one quart Rustolem flat or saten black mix 50% lacquare thinner and three ounces of mineral spirits. What a great finish soft looking protective and smooth. I liked it enough that last week I did my whole pick up. It turned out great. |
| underhood area?? | GearHead69 | Body - Exterior | 9 | 04-30-2004 04:55 PM |
| Underhood wiring diagram for a '80 Vette | V8 S-10 | Electrical | 0 | 03-17-2004 10:34 AM |
| 69 Camaro Big Block Underhood Photos?? | EricTopless68 Camaro | Engine | 4 | 03-10-2004 06:03 PM |
| Underhood oil gauge? | Jag Daddy | Engine | 19 | 12-15-2003 07:33 AM |
| underhood aluminum cleaning? | Custom95Z | Engine | 2 | 07-10-2003 12:56 AM |
