Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Underhood oil gauge?
Old 12-11-2003, 12:58 PM
tm454 tm454 is offline
Tazz
Dude the troll is playing with you. Yes they make a small oil pressure gage. I got mine from a motor cycle shop and installed it in the front of the block just back of the water pump mount, passenger side front, there is a hole with a small plug in it, just remove the plug and screw in the oil pressure gage. Put teflon tape on the threads and a finish tightening it up with a small wrench. If you take the plug out first you can take it with you to match up the thread size.
Todd
Rat Rods Rule!
