Underside Paint??? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-08-2012, 07:18 AM
Here is my 2 cents. We just finished a 51 ford F1. The frame was blasted and 2 wet coats of SPI epoxy sprayed. 3000 miles later looks like the day it was shot. Oil from the transmission wipes off and no chips. The new black has UV built in so no more chalking. I will do this on the next one, nothing over the epoxy.
  #17 (permalink)
Old 02-08-2012, 08:10 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
the last 2 builds i used spi epoxy then spi bed liner. the bed liner can be reduced to what ever texture you like. good gloss, very durable .
  #18 (permalink)
Old 02-08-2012, 03:18 PM
Epoxy prime
Awsome!! just depends on the look your after! Epoxy is good stuff!!
  #19 (permalink)
Old 02-08-2012, 03:45 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Shine,
Did you still spray Lizardskin inside even after the Bedliner?
  #20 (permalink)
Old 02-08-2012, 04:05 PM
shine's Avatar
SPI Thug
yes , lizardskin inside bed liner on the bottom .
  #21 (permalink)
Old 02-08-2012, 04:18 PM
35WINDOW's Avatar
Thank you-
  #22 (permalink)
Old 02-23-2012, 07:05 AM
cmon go for the gusto ,sandblast epoxy, fillerr primer and about 400 hours of block sanding,im happy with it,
second pic paint was still wet.eastwoods ceramic chassi black
  #23 (permalink)
Old 02-23-2012, 04:00 PM
eastwood ceramic black
Nice!!!!
A perfect sheen!!
Your car? nice job!!
I've been looking for a nice chassie black, ever since the new voc laws up here in Canada its hard to get what i want, will have to see if I can get that here!!
most of my customers would'nt pay for that level of perfection, but I have a GTO that I will be doing soon....
All that hard work paid off!!
Thanks!
  #24 (permalink)
Old 02-24-2012, 06:48 AM
i order it right from eastwoods,i gets sent via fedex, no proplems.
i too am screwed by the new laws,im ready for paint and dont know wat to use waterborne or crappy solent,i hear the prospray makes a decent solvent.
im leaning towardfs ppg envirobase waterborne.this is my first paint- body job so im learning.you can get spi clear here.im using that.you gotta reduce that ceramnic paint at the %20 recomendation to get it to flow,i test sprayed 5 times before i was happy
  #25 (permalink)
Old 02-24-2012, 01:59 PM
Eastwood ceramic black
Awsome! thanks!
I've been painting for a long time... been through alot of changes, i've used Sikkens waterborne and Aquabase waterborne and both bases are nice to use, its the clears that are not as nice as the oldschool clears they were "skinny"" pound it on how you want it to look and a variety of speeds and qualities, not thick like todays clears, completes are more of an effort as everything is geared to match OEM peal!! if you come up with a nice "glamour " clear for completes let me know,
Thanks for the tip on ceramic black!
Keith
  #26 (permalink)
Old 02-25-2012, 02:53 PM
would you feel fine just leaving it as epoxy? Now that SPI has the new Ford Red Oxide epoxy, that's what I'd like to do for the underside of my Mustang. The original red oxide coating on it now is almost in mint condition, I'd just like to get some new coats on to make it look consistent.
What to paint underside of hood with?? STATUTORY GRAPE Body - Exterior 3 05-16-2008 07:37 PM
cleaning the underside cares Body - Exterior 3 08-22-2007 06:21 PM
base/clear paint for underside of vehicle or other paint? hrc200x Body - Exterior 5 06-27-2007 09:55 AM
what to paint underside of floor with? TheCiscoKid Body - Exterior 6 08-10-2006 02:31 PM
Cleaning Up the Underside...How?? TorqueAddict General Rodding Tech 19 12-10-2005 08:00 PM
