I did my Dad's 66 Nova with epoxy, then a satin black single stage paint. Looks great, but this isn't a DD or bad weather car, only driven on nice sunny days. The last car he had, a 70 Chevelle, we just did the epoxy. The guy that purchased the car, still looks great 5yrs later, once again only driven in nice weather.
Thanks for the info guys.I ordered some SPI epoxy Thursday.I talked to SPI guy and he said the epoxy is the best around so I'm going to spray 2 coats and that's all.I've done alot of research and I haven't heard anything bad about SPI epoxy.
Now what is a good seam sealer that will last without cracking etc. Nice weather driven only. |
seam sealer........
Hi,ive had good luck with the gray seam sealer from eastwood..
I have a 67 GTO Convertible that I will do a body off come spring. I have been doing everything on a car except transmissions since 1965 and I think that the GTO will be the last car that I have in me. All of my other cars and future cars will be at the level of just light maintaining. I wanted to give you a pointer after reading that you used undercoating on a car like this. All of the guys that I know who have been doing body work for decades (like myself) do not use undercoating anymore as we found that from a tiny tear from rocks, road dirt, etc in the undercoating allow moisture to get trapped between the undercoating and the steel and then rust, then rot. For sound deadening we all have been using an inexpensive form of Dynamat (or you can use dynamat) from Lowe's that stops engine heat, deadens the sound and goes on easy on the inside of the car. An inexpensive version of Dynamat that does the same thing. Jack |
If the car is not going to be a DD but a fair weather driver, I would paint the bottom, then get some ChipGuard and shoot over that. It might have a slight orange peel to it, but it will shine the same as your paint. the chip guard is what you see sprayed on the lower fenders and rockers of newer cars to protect them from road rash. |
Everyone has their opinions, and I'm no different
-on my Car, I used SPI Epoxy, then I Seam Sealed it inside and out (after I Epoxied the Floor inside). then I scuffed it, used W&G remover and used SPI Bedliner on the underside-it looks real good, and it definitely took the "ring" out of the Sheetmetal-just a thought-
I've painted my frame with Endura EX-2C (polyurethane), and thought that I would also paint the underside (actually ALL high-abrasion areas including the inside of the pickup box and door sills, etc) with it. Nice and shiny, and tough as nails.
It's fairly legendary paint in this area, at least. The boxliner stuff sounds like it would be a great idea in the wheel-house areas. |
I've used POR 15 on several undersides. The first one was 15 years ago. Still looks like the day i put it on. What is nice is it sticks to rust so if you have a few nooks and crannies that are not 100% clean the stuff still sticks.
Rotisserie
Does anyone know of anyone who has a rotisserie in the Abington MA area? I want to put my '78 VW bus on one to replace the wiring and brake lines and to paint underneath.
Thanks in advance, bob |
Underside paint
Your all right, but if you choose to undercoat and don't spray some kind of paint over it, it is hard to keep looking nice, the rubberized coating gets grey and dull, I usualy use a 2part eurethane boxliner over epoxy, it has the same texture (its Shiny) but is tough and easy to keep clean, I've also applied the boxliner over sanded por15 thus the rust protection, the factory undercoat was a joke back in the day and quite often was just splatted on here and there, I have a lot of people ask me if they should go for the "package" undercoat I always say no just clean the under carriage a few times a year to prevent dirt buildup in the nooks and crannies,
| What to paint underside of hood with?? | STATUTORY GRAPE | Body - Exterior | 3 | 05-16-2008 07:37 PM |
| cleaning the underside | cares | Body - Exterior | 3 | 08-22-2007 06:21 PM |
| base/clear paint for underside of vehicle or other paint? | hrc200x | Body - Exterior | 5 | 06-27-2007 09:55 AM |
| what to paint underside of floor with? | TheCiscoKid | Body - Exterior | 6 | 08-10-2006 02:31 PM |
| Cleaning Up the Underside...How?? | TorqueAddict | General Rodding Tech | 19 | 12-10-2005 08:00 PM |
