Understanding Cam Specs a bit more. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2008, 08:36 AM
Farmer Buck
Hey, Big time Cam Guys!!! (Not to be confused with "Big time Car Girls" +GRIN+ )---You folks have helped me in sorting out cam info, and I've bought the cam I wanted for my project through your help.
As I've went through countless books and catalogues on different cams I'm still somewhat confused on how to read some of the information. Maybe you could straiten me out.
Trying to understand how Duration is listed. Some cams list duration at .050", example 207/213. ---Some list Duration as "advanced" and usually have one figure, such as 266 degrees. --Some listings just list Duration, and give one figure, I suppose there is some settled upon standard? --I don't know how to compare the figures, and I don't know what the two figures are ie: 207/213. (When I bought my cam from Summit, the teck told me it was 210 duration. I don't know how that compares with two figure stuff, and "advanced" vs .050". )
On one of my vehicles, a 91 F150 Ford, the speck sheet lists duration info as INTAKE Closed 72/82 INTAKE open 196/212. And EXHAUST Closed 76/84, EXHAUST Open 190/210. ----If I'm to compare this information with the ONE figure stuff like the Summit teck does, What would be that duration? And how do you arrive at it?
This is not a world shaking problem at all: Just an interest one. I'd like to be better able to know and understand what I'm reading.
Thanks folks! Appreciate your time!
Old 01-10-2008, 12:31 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi F-Bird & Lloyd,
That was a good article F-Bird, but like most of the stuff
written in the mags, they don't go far enough, they
leave you hanging wanting & sometimes needing
more information, I realize the information is on the
net, but if I payed the $6. for a mag., I'd want all the
info on that subject.
Take care,
rich
Old 01-10-2008, 01:17 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
You have to understand that some of the angles are measured in crank degrees and some are in cam degrees. Since the cam rotates at half the speed it gets confusing. Once you figure it out, its simple math.
The only "standard" is the @ .050 measurement. Some companies do their "advertised" at .002 lift, some at .004, some at .006. Although they're all different, as long as you know where its measured they're all important numbers.
Old 01-10-2008, 03:08 PM
malc's Avatar
Living At The Speed Of Life
Understanding Camshafts at CHP.
Old 01-11-2008, 03:06 AM
malc's Avatar
Seems like I goofed.
Posted a link that was previously posted.
cam shaft specs azza250 Engine 2 12-05-2003 12:01 AM
L88 cam specs Tiros Engine 1 11-03-2003 12:52 PM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 08:52 PM
Anyone know the stock cam specs from a '73 Ford 302? 66StangBoy Engine 10 11-23-2002 07:06 PM
Cam Specs 66chevy2ss Engine 3 09-12-2002 03:40 PM
