unearthing the caddy 500 facts? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2014, 07:39 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Hey.
Looking at a 75 caddy 500 n tranny. I know these are rated at like 195 horses but there's no way!
I rode in a mid 70s cad and other than the scrappy gearing slowing it down outstanding the hole it kicked in and was flat moving!
What's the scoop on em? HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 01-19-2014, 08:14 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by HemmiGremmie View Post
Hey.
Up through 1971, motors were rated for hp and torque without having to operate anything on the outside of the motor, like fan, power steering pump, etc. After 1971, they were rated with all the accessories that they would have to operate in the real world. These accessories bleed power from the motor, so the observed dyno runs showed the motor making less power.
Old 01-19-2014, 08:53 PM
327NUT's Avatar
As Tech says.......also in '71 they dropped the compression from 10.1 down to 8.5:1, I took this pic out of the "Maximum Torque Specialties" engine tech guide book.
Old 01-20-2014, 06:08 AM
Accurate published horsepower figures for late 60's and early 70's performance cars is hard to determine. The combination of rising insurance rates and the change in how they measured horsepower (with/without accessories) makes it hard to compare data from year to year.
For performance cars in the late 60's they also lowered published performance data just to try to keep insurance cost down. For example, Ford rated the Super Cobrajet 428 at 335 horsepower, which was the same as the horsepower for the performance 390 in 67-68. Actual street horsepower for the 428 was probably over 400, and when set up for racing (higher rpm, bigger carb, etc.) it could get even more horsepower without breaking anything.
Bruce
Old 02-14-2014, 12:07 AM
I had a 500 Caddy in my Camaro, and it had bottom end torque that would smoke the tires for as long as you wanted to hold it to the floor
Old 02-14-2014, 05:49 AM
Wiki Edits: 27
sawmill power
I have a 472 Caddy running the 48 in blade on my sawmill, Lots of low end torque where I need it. But it did get a real workout cutting some BIG western Juniper trees for a friend.
caddy 500 help Blown496 Engine 1 08-11-2013 06:11 PM
caddy 500 50 ford Hotrodding Basics 6 07-26-2013 01:11 PM
'74 Caddy 500 c.i.d. choirboy Engine 8 01-29-2009 07:56 AM
CADDY 500 question jvsapp Engine 10 12-21-2007 06:20 PM
500 Caddy rhanshaw Engine 23 08-07-2007 02:53 PM
