Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Uneve Brake pad wear on 2001 Malibu
Old 04-07-2004, 04:04 PM
19_Chevelle_69's Avatar
19_Chevelle_69 19_Chevelle_69 is offline
Just making my rounds...
Last journal entry: Propane stuff - 2
Actually, the uneven brake wear on the "N" chassis cars (ie. the inner pad wearing out before the outer pad) is a normal condition. Now, if the pads are SEIZED into the bracket, that is usually caused by rust building up under the shim on the bracket side.
I have yet to see a seized caliper piston, but we usually don't see many very high mileage cars at the dealer.
There have been quite a few times where the calipers creak or squeak when appying the brake, but that has turned out to be the piston contacting a small area in the bore of the caliper, but not a siezed piston. This is/was a common condition with all "N" body cars. Malibu, Grand Am, Alero.
Don
GM Tech Guild - Grand Master Technician
1969 Chevelle 355/TH350/3.08
2001 HD Sportster 1200
