Uneven brake pad wear. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2012, 04:13 PM
What causes uneven and premature brake pad wear on Chevrolet S10 Blazer 4x4 front pads.
The portion of the pad with the "squealer" wears thin with a few hundred miles.
Old 10-29-2012, 04:16 PM
poncho62's Avatar
Wiki Edits: 5
Sliders are probably seized......That is the part that the caliper moves sideways on...Keeps it centered
Old 11-09-2012, 05:54 PM
uneven pad wear
caliper hanging up, faulty brake hose, not enough clearence between brake pedal push rod and master cyl causing brakes to drag
Old 11-10-2012, 05:44 AM
Thanks.
I am going to replace the pads and inspect the calipers. Since these are GM single piston floating calipers, the problem may be the caliper is hanging up. The piston is pushing the inboard pad into the rotor but the caliper is not pulling the outboard pad into the rotor with equal force.
I may replace the pads, calipers and rotors. I replace the flexible brake lines two years ago and they seem to be in good shape with no kinks.
Old 11-10-2012, 02:41 PM
uneven pad wear
brake hoses can deterioate inside and act similar to a check valve and not allow brake fluid to return to master cyl
Old 11-10-2012, 05:12 PM
LATECH's Avatar
Sliders are seized, or move very hard.
The o rings inside the bores that the mount bolts go into have rust behind them, making them grab too hard to the bolt / slider pin , keeping them from sliding easily, this keeps the inside pad applying harder than the outside, wearing them un evenly
Take the calipers off and see if the slider barrels move easily. If not, then pull out the o rings and clean out the rust, lube the O rings with a suit- able brake grease,re install. Dont forget to lubricate the contact points of the brake pad itself, you know...where the pads touch on the caliper mounts. They can become seized at that point also, resulting in the same condition.
Be sure they move freely on the mounts before putting the caliper back on.
Fact is stranger than Fiction
Old 11-11-2012, 08:11 AM
Thanks again, Before I replace the calipers, I will install a brake kit. I purchased an ACDelco 18K256X (GM 1926240) brake parts kit which includes inner and outer O-rings and steel slider pin bushings. Also install Raybestos ATD154C Ceramic brake pads. I will replace those parts and lube clean and lube everything with Permatex Ultra Disc Brake Caliper Lube #20353.
ACDelco, Made in China
Permatex, Made in U.S.A.
Front Disc Brakes- uneven wear question ChevelleSS_LS6 Suspension - Brakes - Steering 2 05-08-2011 05:13 AM
brake pad selection mitmaks Suspension - Brakes - Steering 1 08-14-2009 06:41 PM
Brake Pad Info Triaged Suspension - Brakes - Steering 0 03-27-2005 11:44 PM
Brake wear tnoftsger Suspension - Brakes - Steering 0 06-08-2004 06:40 AM
Uneve Brake pad wear on 2001 Malibu Malibucdl Suspension - Brakes - Steering 17 04-09-2004 10:13 AM
