Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Unfortunate Starter problems ?
Old 06-23-2013, 07:33 PM
78C10 sleeper 78C10 sleeper is offline
Does it have a support bracket on the end facing the front of the car? If not it can move around and jump teeth. Mine started acting up one time so I replaced it and it stoped then about a week later it started grinding agin. so I had my friend hit the key while I watched it and the starter was jumping around and skiping teeth. So I made a bracket and two years later it hasn't miss a beat. The bracket goes from the starter to the motor mount. If that is your problem the I can give u more details about the bracket.
The Following User Says Thank You to 78C10 sleeper For This Useful Post:
stratt134 (06-25-2013)
