Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Unfortunate Starter problems ?
Old 06-25-2013, 11:07 AM
Project89's Avatar
Project89 Project89 is offline
Originally Posted by stratt134 View Post
hes refering to all the reman ones u get from the local parts store , mine didnt have enough engagement without any shims, right now i have the outer bolt shimmed with an 1/8th inch shim and its still shy of having the right mesh.
probably needs another 1/16th worth of shim
this is the 3rd starter ive had i made them warrenty the first 2 and all 3 same issue, its like they cut the mating surface on the starter were it meets the block
The Following User Says Thank You to Project89 For This Useful Post:
NEW INTERIORS (06-25-2013)
