Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Unfortunate Starter problems ?
Old 06-25-2013, 01:03 PM
Project89's Avatar
Project89 Project89 is offline
Originally Posted by stratt134 View Post
I'm going to order a new starter soon regardless... but do you think that will fix the issue? I'm assuming there is still a problem with the flywheel ?
Thanks for the help everyone
u will have to inspect the flexplate and see how much damage to the teeth there are.
i will say my starter did exactly what ur did in the video and i was able to put a new starter in shimmed one side without changing the flexplate as i didnt let it grind enough to adversly grind away the teeth on the flexplate
