Unidentified GM engine code - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2008, 05:56 PM
Crazy Fast on Ice's Avatar
Loose is Fast
I have a small block chevy that I took out of a 67 chevy 1 ton four-wheel drive. The man I bought the truck from said the motor was original. I only paid a hundred bucks for the truck so I was doubt full that I actually had the 327 I was looking for. I tried to check with the casting number (it is 3970010) which I am familiar with and realized after seeing it that it would be way to broad. I cleaned up the front of the motor and got V05I8KCD off the flat portion of the deck where the engine code is. The code seems very authentic, the numbers are in perfect line up spaced evenly does not seemed to be tampered with. They are also evenly indented into the block. I can not make any sense of this code it does not follow any of the "rules" of gm code. I realize it should be the plant then the date then the vehicle or exactly how it was used. I haven't had time to tare down the engine and check stroke dimension, but that is my next step. I would like to find out what this engine code is. If anyone has anymore info they could provide I'd much appreciate it.
Thank You
P.S. This truck could possibly be a 68, it was majorly rusted out and the steel the tag was on even rusted off. From the body, hood style it had to have been a 67 or 68 though.
Old 10-05-2008, 07:09 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Go to this site: Mortec
Go to the bottom of the page and email the serial and casting #'s.
Nice guy. He emailed me back about 1/2 hour later.
Let us know what he says.
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 12:53 PM
Whats the correct temperature my 350 should be running at? batman09 Engine 101 10-23-2005 01:29 PM
firebird engine code g018 possumho Introduce Yourself 2 09-30-2004 11:51 AM
New Engine Built & Dyno'd babe_n_indy Engine 69 09-09-2004 08:26 PM
Verifying engine pedigree... johnnya Engine 3 08-04-2004 07:42 PM
