That is a Torqueflite filter spacer, that lowers the filter, when a deep pan is installed. It is installed between the filter and the valve body.
Hey Junior..A powerglide trans filter is attached to the valve body by 2 bolts..A torqueflite filter is held on by 3 bolts,which is a different thread and location...Please tell me how this works on a powerglide trans.I'm allways open for new info pardner.
Does not look like the PG adapters I have seen with a mopar filter bolted on.
Looks like the filter extender various companies offer for mopar TF trans with deep pan. you can also modifiy that extender for late design 2 bolt plastic mopar filter
At the Bonneville Salt Flats, first gear is known as 130 mph. Last edited by Crosley; 03-17-2013 at 07:37 AM. Reason: fergot sum words , sorry |
Yes..TF filters are round hole ...PG are rectangular hole...This is clearly a round hole..this is NOT an Adapter.
I believe it is Rancho Transmission in Calliefornia that builds a T-400 pickup tube with dual small Mopar brass filter screens on it. Rancho builds off road race trans I tried to find a photo of the PG with Mopar filter. I have photos some where.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
that piece is a filter spacer used on a hipster powerglide aluminum valve body.the valve body was made with the round pick up hole and the 3 screw holes.
| Unidentified Engine ID | haas302 | Engine | 4 | 01-03-2012 03:29 PM |
| Cost No Object Interior Dye and Process | H1LM002G55 | Interior | 8 | 08-26-2010 10:11 AM |
| Unidentified GM engine code | Crazy Fast on Ice | Engine | 1 | 10-05-2008 06:09 PM |
| unidentified engine | Craig Davis | Engine | 6 | 04-30-2007 07:32 PM |
| Unidentified Mopar V8 | bobbypantera | Engine | 6 | 05-14-2005 07:52 PM |
