Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - A unique BBC application
Old 10-20-2009, 06:49 AM
Guy Hiltz's Avatar
Guy Hiltz Guy Hiltz is offline
With those heads you may want to shoot for 6500 rpm to meet your goal.I dont know anything about reverse rotation cams,but you could call UDHarold Brookshire for a custon grind,662-562-4933,or 662-301-1245.You may also want to consider going with a solid roller cam.There are better intake manifolds available,the one you have is decent,but its an old design from the 60's.A Weiand Stealth would be a better choice.Your carb is a bit on the small side,an 800 might be better suited,and your timing is too low,big blocks like to have 36-38 degrees BTDC total timing in by 3-3500 rpm.If I were you,I would work on this combo before going stroker.
