Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - A unique BBC application
  #45 (permalink)
Old 01-26-2010, 10:07 AM
bentwings's Avatar
bentwings bentwings is offline
bentwings
I forgot about the wet manifolds but doesn't the water that cools the manifold get dumped into the pipes a ways aft of the manifolds. I had a humps on my my old boat and the water entered the pipes aft of that then out the transom. If so you could inatall the 02 sensor between the manifold and the humps. It can not get wet however. You could even run a temporary one into a check port for it then remove it for running after you get it set up.
