Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Unique cooling problem??
Old 04-06-2010, 08:06 PM
Scrumgees Scrumgees is offline
thanks for the reply but im still unclear one one thing. why once the engine warms up and the thermostat competely opens, and i have verifed this pulling off the thermostat neck while the engine is good and hot too, is there still absloutly no flow through the radiator? at some point it should begin to flow right? This problem is present from idle all the way to the top.
I forgot so i should also say, following a hunch, i figured maybe it could be pressure related problem holding the thermostat closed so i tried flipping the thermostat up side down and it actually got the temp down to 210 from 250 degrees. My gut says its just spinning that impeller in an air pocket though.
